Hi i got a 65 that i put a 1968 200 block with a late 69 head.the intake bore is about 1 3/4" and bolt spacing is about 3 3/8" center to center mounting bolts to intake. I don't want to change head as it is redone...i can use a 69 or 70 carb....what to do about spacer base???? Thanks!!!
Discussion Starter #2
Found a 69 carb base,i need to do some welding, but is there a adapter available to be bought any where???
Why don't you just use a 69 carb?
Spacer plate
THE 69 SPACER BASE IS NOT FOR A MECHANICAL LINKAGE.THE 69 70 CARB USES A CABLE:shrug:I LIKE TO KEEP MECHANICAL CARB LINKAGE
