1969 Mach 1 & 1969 Grande
I found a topic on this from 2014 but the question was never answered.
The valve covers on my engine are the same left and right. They both have an opening for a twist in cap (left cover opening at front, right cover opening at back).
In the pictures I can find, they only show a rubber grommet on the right side cover in the back where the PCV valve would go.
Are my covers correct of did someone in the past put a left hand cover on the right hand side?
Any input appreciated.
Gregb
Thanks for the response. So they changed to a pressed in grommet in 1971?
I have bought two sets of valve covers (my are pretty dinged up) that were listed as 1970 - 1974 and both sets have a small round hole in the right cover with a push in grommet.
So i guess I could use the two left hand covers to create a correct set for my 1970?
Yes, you can do that. I put 1970 Boss 302 valve covers on my Cleveland and they are the same way with the larger holes in both covers.
FYI, I ordered the PCV grommet from NPD twice and twice I got the smaller grommet. I finally had to call and ask someone to go to the parts pin and pull out the correct, larger grommet. Apparently, the part numbers were the same for both grommets.
Thanks Klutch,
gregb put a link for the grommet at Dennis Carpenter.
