Checkout these custom valved, Bilstein double adjustable coilover shocks we built for a customers '70 Mach 1.
Available as an upgrade on our coilover system, these aluminum bodied shocks are essentially 3 shocks in 1. Set both dials to #1 and you have our Street valving, #5 is Sport and both at #10 is our Race valving.
With so many options available for these cars its important to understand what you are getting. Would you buy a camshaft and expect it to arrive as a plain billet of steel? NO! You'd want the profiles professionally mapped out and ground by an expert, someone that knew and understands how to get out of your engine what you want.
Why then do people buy shocks that are not tuned specifically for your car from companies that don't employ specially trained shock & suspension engineers? Its like that billet of steel, it fits the gap but isn't optimized for your vehicle or what you want to do with it. The end result is you may say your car has coilovers but the ride quality will suffer and longevity of the components will be questionable.
Big wheels need big brakes. How about a third shorter stopping distance? Yes please. See how:
https://www.hotrod.com/articles/street-track-vintage-mustang-brake-upgrade/
Here's another bonkers build with Street or Track components. Heath loves the sleeper look and doesn't plan on painting the car anytime soon. His '69 is running our front/rear coilover systems and our 14" front 6 piston and 13" rear 4 piston big brakes under 18" wheels.
@Shaun
If I run with this set up, what size tire would be best. Canyon carving '68 coupe build.
SoT Front Bilstein Coilover System (Sport, shaft bump stop, camber kit, Moog ball joints) and Big Spindles.
SoT 13x1.25" Rotor 4 Piston Forged Aluminum Caliper Brake System. (New master cylinder...
So, Im looking at upgrading my brakes and thinking spindles might be a good idea too.
Info on my car:
'68; 307ci 460ish hp. Sport style suspension.
Im looking at adding a Wilwood: 12.19" Dynapro 6-Piston Front Disc Brake Kit. With power boosted Wilwood Master Cylinder.
Will the Wilwood disc...
Did you see the testing of our front coilover suspension system in this months Mustang Monthly?
We love the way Dave Stribling cuts through all the fluff and actually brings the tech. So many articles are just install articles but Dave actually tests the promises of the manufacturer. We...
