Hello all. I am currently looking at a 1970 Mustang Fastback that originally came with a 302 (not boss) and thinking about buying it. However, the wiring harness is completely missing as is the engine and dash. How hard is it to rewire one of these? Also I’m open to any suggestions of which harness I should get. I’m thinking about putting an old 302 (not EFI) back in it. Thanks, Daniel
Welcome to the board. You can get all of this stuff. It depends on whether you use a factory type repro or non factory type. Ultimately what will effect value is the workmanship.
I would take a honest step back and re-evaluate if this is what you're able of doing both financially as well as skill. Nothing will kill enthusiasm quicker then a pile of parts on the garage floor sucking up your money with no end in sight
Welcome, 69 - 70 Fastbacks are highly desirable, what shape is the car in?
Everything you’ll Ever need can be found here on this board.
Anything that needs to be done, someone here has already done it, and will walk you through it.
