Only place i can think of would be Radio Shack, but why bother,you could keep power on it to show someone it lights up, but do you really want to listen to it? the A.M. radio that is, if you want it to make noise,stick a peice of wire in the antenna jac, center hole ,not allowing it to touch the round outer shield in the case, im talking about the center small hole deaper inside, make sure its firmly in, longer the better ,but any length will work to some degree, even a long thin screw will work, if it touches the outer round shell, it wont work at all,. unless your into A.M. listening? its good enuff
Moderatly Old Fart
Radio Shack has it. The antenna is a male and the radios need females. The adapter I got had a plug for the male antenna, a male cable which went in the AM radio and I bought a short male to male cable.
Works great! I have had it for years!
