Title says it all.
I found out that the bolt is a special torque bit which i have in my tool set but then i tried to bust it loose going righty tighty, lefty loosey... then found out it is very likely a reverse threaded bolt which means righty loosey , lefty tighty... so with my breaker bar i attached to my ratchet and put lots of force on the bolt turning CLOCKWISE to loosen.. am i doing all of this right?
The bolt hasnt budged once and i sprayed some rust and carbon inhibitors on the face of the bolt and everything i could that was exposed....
tried it again 45 minutes later and somehow ended up slipping which kind of stripped the star pattern inside the bolt.. not getting a good grip inside anymore.
What do you guys recommend i do at this point? would it be safe to heat it up with a torch and beat it with a hammer to knock some of the rust loose? I have a big job starting my work tomorrow at 7 and my life is nearly ending over this BOLT!
Recently I was replacing the tensioner pulley on a '91 Explorer 4.0L. Only the pulley bearing was bad so I got my ratchet and a 15mm socket and gave a heave-ho Lefty Loosey pull on the ratchet. The bolt was turning but it wasn't backing out. UhOh- it's a left hand thread bolt that screws into aluminum. So I got to replace the entire tensioner assembly. The bolts attaching it to the engine were right hand thread. I'd bet yours is the same.
Once again this is NOT the bolt inside of the pully... it is the bolt that sits inside of the tensioner assembly.... its a torque bit T-55 ... just stripped the insides 2 minutes ago
Re-read what I said. The bolt in the center of the pulley is left hand thread. The bolts that attach the tensioner assembly to the engine are right hand thread.
