Well, all of you with electric fuel pumps, I strongly recommend this simple modification to improve your safety if you are in a serious collision.
I purchased Ford part # XF3Z-9341-AA inertia switch. It gets wired in series with the power to the electric fuel pump. I also purchased the mating connector, part # 96-7552.
The inertia switch was about $12.00 and the mating connector is about 10.00 at the dealer, but only $4.00 from a Ned R. Healy distributor (You can look up where your nearest dealer is at this site:
http://www.nedrhealy.com/home.html).
Anyhow, when the car is involved in a collision, or receives a serious shock, the switch contact breaks, cutting off the power to the fuel pump. I plan on wiring this in, and actually adding an LED to one of my accessory switch panels and label it as 'Self Destruct Enabled' for theft protection.
Anyhow, I think it is one of the best things to do on your car. All new fuel injected Fords have this type of switch somewhere.
http://albums.photopoint.com/j/View?u=1571478&a=12287439&p=44845480.jpg
Sounds like a perfect opportunity to graft on a hidden kill switch in the same circuit.
Rich
'67 C-code 'vert (Dees67)
'69 GT FB (project car)
Check out my band: Brickyard Blues
ya, I've done this, the hidden kill switch, on my electric fuel pump. Since, I removed the windshield washer pump and related stuff from my fastback. I wired with a relay, so once the ignition is on, i have to pull the washer knob to engage the fuel pump and the relay keeps it on until you shut off the ignition.
I've added a light on the dash, for when the fuel pump is on. I've forgotten to turn it on a time or two and you don't go very far with just the gas in the carb. *LOL*
It does sound like a good idea to add the inertial relay.
Rob
Member: Slightly Modified
66 coupe 302
66 fastback 351W
Good suggestion. I added an electric a few months back. thanks!
http://66cherry.stangnet.com
Member NTMC
http://albums.photopoint.com/j/View?u=1611748&a=12299913&p=44922660.jpg
66 vert, 5.0L custom roller motor
99 Expedition
90 Caravan
Steve,
Thanks for the info. I'd heard about this before and had planned on checking into it. I'm putting a fuel injected 5.0 in my '65 fastback in the future. I had no idea this was so cheap to do. Definitely worth the money.
Thanks again.
Bob
