The book says there are drain plugs on both sides of the engine. I only see 1 on the passenger side. I took the oil filter off but :: still a no show on plug. What is up with that?
What do you mean by drain plug? If you mean the oil drain then there is always only one unless its a custom fabricated pan.(stock and most aftermarkets will only have one)
If you are talking about the water drain plug, it is towards the rear of the block on the drivers side......At the same height as the one on the passenger side, but underneath #8 header tube......
Gary.......::
