1 - 17 of 17 Posts
Hi folks, some much appreciated advice would be helpful. I’d like see ideas on restoring the bay, and what to change, what to keep etc. I personally don’t like the snorkel so the cover is going for a nice shiny new one, but open to ideas on the rest? Relatively new to all of this so all advice would be great. Cheers All.
1968 289 2V - C Code
754372
754373
Well heres where I am at on a quick refresh of the engine bay. The more you dig, the deeper the hole, peel back a layer on the onion, whatever you want to call it, its always a bigger task than you think it will be.
If you're leaving the engine in, it's a LOT of work the take off all the things bolted to it except the valve covers and maybe the carb, clean everything, mask off and rattle can it or use a gravity fed gun with the right color blue, spray all the bolt-on stuff with the right black etc, let it all dry, re-assemble then mask it off... THEN disassemble everything from the bay, clean and spray all that black and re-assemble. Clips, screws, wires, labels, etc etc etc you'll want to replace along the way...
You need to know what you want for the finished product. I did my 68 with the engine in the car. I even pulled the motor mounts and had the crank sitting on a 2x4. I pulled the oil pan and painted it by itself.
754451
754457
754458
That's what I'm talkin' 'bout. Looks good! Last time I did that to mine was 1993. I did swap to chrome vc because they're easier to keep nice and chrome air cleaner for the extra flow.
There's nothing better than a clean engine bay. It can be a fair amount of work, but it's very rewarding. I've done both engine in and out refurbs, and it's certainly do-able either way. Thing is, it's really not that much more work to pull it. The potential pitfall is it can be daunting when you have the engine/driveline out, if you aren't super motivated, it can lead to prolonged jack stand position. That's not good.
Share some more specs on your 68!
With not too much effort, I’ve come this far, which I’m pretty happy with so far. A work in progress:
Here a couple more.
754962
754963
754964
754965
754966
754967
754970
754968
754969
Reactions: 68Ghost and Rowdy
Wow, you really did an excellent job - looks great!
Is sitting on the jackstands a while really that big an issue if the engine is out?
What black paint is that?
Krylon 1613 - the old stuff....not sure you can get it any more. I bought a bunch when we found out they stopped making it.
Reactions: Bernnstang
Wow. What an inspiring thread and photos. Here is my before shot. I wish I had an after shot but it will probably be a while.
Sent from my Pixel 3 XL using Tapatalk
1 - 17 of 17 Posts
