Then I'd be off to the scrap metals yard to see how much scrap cast iron is going for by the pound... :thumbsup:
Then I'd be off to the scrap metals yard to see how much scrap cast iron is going for by the pound... :thumbsup:That block is already at .060 over. There's no room left to bore.
Tim,I'm starting this to post progress on my engine build. My son and I are going to put this engine together.
I have gotten a 1965 289 block. It's cleaned, decked, and bored .040 over. The shop is going to install cam bearings, soft plugs and paint it black. Then we will start working on the crank shaft. ( I still have to get that out of the old engine )
I will be reusing the heads from my old engine and anything else that I can salvage.
In the book How to Rebuild the Small-Block Ford by George Reid, considered an authoritative text by many, it states that anything up to .030 overbore is perfectly fine on a 289. Boring to .040 over is possible but not advised. The reason has nothing to do with overheating. It has EVERYTHING to do with the risk of punching thru to the water jackets. The 289 walls were notoriously thin by design, and boring to .040 and beyond COULD result in disaster due to the non-uniform thickness.Quick question: A retired machinist I talked to told me not to bore over .030 on a 289/302 because it will start to have over-heating issues. Wonder if that's true?
Your reply is quite interesting. With my "new 66 Fastback" project which I bought from my son come three 289 blocks. My son bored them out when he went to vocational school "Automotive Industrial Machineing". As I recall he said they were bored out to the max and now have 349 cubic inches........ can that be correct? And if so how much over would that have to be? These three blocks were oiled down, wrapped in poly and then put in a poly bag...... been there for 24 years. He also tricked out a set of heads.A 289 block that is .040 over may run alright without any overheating problems but .060 will overheat in most situations. Sure you can go to a 3 row alum. radiator, high flow pump, elec. fan, water wetter and on and on but that's not normal or won't look stock under the hood. I have never seen or heard of a 289 being bored .080 and don't believe you could use one for street use. Most of these car's ran a little hot to begin with or that's what the temp gauge would say. This experience with your son will be priceless.
A "349" would be a 289 bored to 4.060" with a 3.40" stroker crank. It would be quite impossible to bore a 289 to 349 cubic inches with a stock 2.87" stroke.Your reply is quite interesting. With my "new 66 Fastback" project which I bought from my son come three 289 blocks. My son bored them out when he went to vocational school "Automotive Industrial Machineing". As I recall he said they were bored out to the max and now have 349 cubic inches........ can that be correct? And if so how much over would that have to be? These three blocks were oiled down, wrapped in poly and then put in a poly bag...... been there for 24 years. He also tricked out a set of heads.
I've thought about building one of them blocks but sure don't want any overheating problems because I'm planning on driving the car not racing it.
More wrench turning please.I know you guys love pictures so here are a few for you. These are of the old block, and the crankshaft and the camshaft. I'm going to try to reuse the crank (after is gets checked out by the machine shop first) but the block and cam are junk.
My son (11) has the same hair as your son - same length/color.That's my son in the pictures. He and I are going to assemble this engine as a father/son project.
I beg to differ.In the book How to Rebuild the Small-Block Ford by George Reid, considered an authoritative text by many, it states that anything up to .030 overbore is perfectly fine on a 289. Boring to .040 over is possible but not advised. The reason has nothing to do with overheating. It has EVERYTHING to do with the risk of punching thru to the water jackets. The 289 walls were notoriously thin by design, and boring to .040 and beyond COULD result in disaster due to the non-uniform thickness.
Boring to .060 will almost certainly lead to a ruined block or engine.
And boring does not affect heating or cooling. What you DO with the motor and what you INSTALL in the motor does.
