I've had the short block completed and balanced, now my questions start. I really intend on using the car for street/travel and would like to improve gas mileage and overall performance ( a little increase in HP would 'feel' good also).
My original heads I will keep ( they are not in good shape), I lean toward possibly Edelbrock Performer aluminum. The following is also considered along with what you knowledgeable enthusiasts suggest.
1. Melling fuel pump with hardened shaft
2. Edelbrock intake manifold
3. Edelbrock water pump
4. Proform alum. roller rocker arms - I still question-will they fit under valve covers ?
5. 289 hipo headers - ?
6. Pertronics Distributor - ?
7. Edelbrock cam - Performer Plus
8. Edelbrock 500 cfm carb 4 bbl
9. Dual exhaust
Again I intend on paying attention on what is suggested from the forum. Thank you, Bill Palmer
If you keep your original heads, you need to do this to take full advantage of your other upgrades:
289/302 Cylinder Head Port Matching
Use the 500 cfm if you are sticking with the stock cam. Otherwise, use a 600. If you want use a Ford cam with markedly better performance, but manners smooth enough for your wife to drive the car, use the C9OZ-6250-C. I'd recommend using screw-in rocker studs and dual valve springs, but these low-cost upgrades are desirable in any engine.
A stock (recurved) distributor with Pertronix I will work just fine, and save a lotta cash.
22Gt, I didn't explain myself very well......... I intend on purchasing Aluminum heads also as part of the list ........ what do you think? Thanks, Bill Palmer
bro you dont need those eldenbrock stuff they are good but go with the more generic stuff like the fuel pump and water pump. i think in this case for mustangs it is eagle parts. that is what i am running and i have no problem. you should be able to save money and then spend it on a aluminum intake but the iron ones arnt bad (that is what i am running).
o and on headers i like the Tri Y's and they fit like a glove as long as you have a automatic (i had to modify because of manual 3 speede but fit like glove after modification).
Get a quality water pump. A lot of the remans are junk. Definately a quality aftermarket intake, moderate cam, headers, dual exhaust.
Cam has to be a good combo with the heads. Sounds like you want a good torque motor which you don't want to rev. Stay mild with the heads and conservative with the cam.
64 1/2 D Code Coupe,
Are you changing pistons as well? If so, perhaps SpeedPro hypereutectic pistons with moly rings would be a good choice. My choice was when I did my engine also included, a Crane Energizer Camshaft kit 130032, with .456 lift, 260 duration, Clevite bearings, Airtex water pump, larger 1.94" intake valves. I'm still running my 1.08 venturi Autolite 4100 carb on Eddy Performer 289.
Stay away from the Proform rockers....these have had many quality issues. Comp and some of the other mfg make good, affordable, steel roller tipped rockers...
Tom
