Whats the difference between a 289 and a 289 HiPo? When I got my '68 Coupe, my girlfriend's dad told me that it had a 289 HiPo, but it only has a 2V....i found that kind of funny. Could someone clear this up for me? Thanks
289 Hypos or K engines were all 4 barrel cars. They were rated at 271 HP versus about 200 gross HP for a 2 barrel (C-code). Yours is a c-code. K engines had slightly better heads, a more agressive cam, solid lifters, a bigger carb, dual point distributor, aluminum water pump, etc. that weren't on the c-code engine. I've found than many people when hearing "289" will respond "Hypo 289". They seem to think they are the same thing. Obviously they aren't. That being said there are many things you can do with a c-code to make it eat a hypo's lunch. I'm currently in progress on a project that will accomplish that (no offense to you k-code owners...take comfort in the fact your car is still stock and worth a small fortune /forums/images/icons/smile.gif). Oh and I don't think they even made hypo 289's in '68. Somebody might check me on that.
BTW.."BeerMan". There's only one VMF Beerman...and you're reading his post /forums/images/icons/wink.gif.
No offense taken . Your right about the '68 model year, there were no "Hi-Po's". In fact if memory serves, there were only 472 '67 Hi-Po's, not counting those fed to Shelby for GT350 production.
65 Hi-Po F/B (7 yr resto)
67 GTA F/B (small block) Mustang Owners Club of Austin (MOCA), TX
MCA 27479
http://albums.photopoint.com/j/View?u=1575609&a=11978710&p=43914197.jpg
Correct me if I'm wrong Phil, I know this isn't my area, nor do I really care /forums/images/icons/wink.gif but didn't the hi-po 289's have 4 bolt main blocks???
[color:blue]'68 Coupe
250/C4, 221 Argentine Head
Breakaway Converter, 9", 3.50's/T-lock</font color=blue>
No. I don't think so. They had bigger, beefier main caps, and they checked brinell hardness on the cranks to make sure they were the best of the stock cranks...if memory serves. Another diffference was better exhaust manifolds or tri-y's on Shelbys, coupled with dual exhaust.
I've been fielding a bunch of Inliner questions....what was the URL of your inline forum again....I'll bookmark it so I can refer these guys...
RE: 289 block....the HP block was a standard 289 block with beefier 2 bolt main caps....as Phil noted, they checked the cranks more thoroughly, and used a heavier duty rod with 3/8" bolts...
The other differences are outlined in the pictures in my other post in this thread....
Pat
http://albums.photopoint.com/j/View?u=1570936&a=11937754&p=42910787.jpg
Actually, there was a 4 bolt main 289 block, as pointed out to me by my racing coharts over on the Boss 302 registry board. Evidently, they came with a C6ME casting (I think) and were used in Ford's racing efforts at the time. Pat (camachinist might/probably knows more about this). As far as the Heche en Mexico block, it wasn't a hipo - have seen several 302 2V sporting the Mexican blocks.- just the way they manufactured them.....
I've heard that some prefer the Mexican blocks because they supposedly were cast using a higher nickel content, which was supposed to make the block stronger.
Myth or Reality?? Your guess is as good as mine - Dickson
1965 GT fastback
There's a fine line between "hobby" and "mental illness" - Dave Barry
1 - 10 of 10 Posts
