BTW, currently the car is a 289 with the top loader 4 speed. My intention is to make this my primary daily ride so the 5th gear is VERY appealing!
I installed mine with one of these plates. A 289 with stock intake and C4 transmission...Are those carb lift plates safe? Especially when using an aluminum intake? I just don't feel safe with it. I have always used a chain crossed between a front head to the rear head. Only two bolts but the bolts are larger and at an angle to the chain.
A lot of people use them. I'm not a fan. I ended up spending a small pile of cash to have a cracked aluminum intake repaired. I blame the plate. The intake is uncommon and was worth fixing.Are those carb lift plates safe? Especially when using an aluminum intake? I just don't feel safe with it. I have always used a chain crossed between a front head to the rear head. Only two bolts but the bolts are larger and at an angle to the chain.
That's exactly what I did. No issues.Are those carb lift plates safe? Especially when using an aluminum intake? I just don't feel safe with it. I have always used a chain crossed between a front head to the rear head. Only two bolts but the bolts are larger and at an angle to the chain.
It looks extremely frightening to me but I've seen lots of them in use. So I finally bought one and use it but I don't lift the engine and trans together.Are those carb lift plates safe? Especially when using an aluminum intake?
The Ford factory put them on. That's what they use on the assembly line to drop the engine/trans combo into place. I think the process is shown in the video of the Supremes singing and dancing on the Mustang assembly line.Don't know where they came from, they were on the engine when I bought it
That's what I figured, I just never see them on other cars. Was the factory or dealer supposed to take them off and return them like the tie downs that bolt to the rear frame rails? Or did they just kind of disappear over the years?The Ford factory put them on. That's what they use on the assembly line to drop the engine/trans combo into place. I think the process is shown in the video of the Supremes singing and dancing on the Mustang assembly line.
