I have 3 carrier housings, and who doesn't?
One from a 3.25 equa-loc, 2.75 that came with the axle housing from a '70 Cougar, and the last one is from a 64.5 K coupe Mustang with 3.89 gears. I was going to do a mix and match kinda thing, :: but it turns out that is not going to work. I am using the equa-loc and I put it together this afternoon. The clutches have been sitting in gear oil for the last week. I had already cleaned and painted the carrier housing from the '70 Cougar. I dropped carrier in place and it would not turn. I adjusted it back and forth and it would not turn. The extra thick 3.89 ring gear was hitting the pilot bearing housing.
So I pulled the housing that the 3.89 gears were in out of my storage shed and lo and behold there is a difference. Note the arrows pointing to a notch in the pilot bearing housing. Also note that the 3.89 carrier has an "X" stamp on it whereas the 2.75 (and my 3.25) carrier has an "O". http://images.cardomain.com/member_img_a/247000-247999/247994_10_full.jpg
http://images.cardomain.com/member_img_a/247000-247999/247994_11_full.jpg
The reason that I wanted to use the carrier housing from the Cougar was because it has a drain plug in it. So I guess that I will have to drill and tap a drain plug in the old 3.89 housing. There is a place made for it, it just was not drilled and tapped. I just noticed another difference in the pilot bearings, "X" has 11 bearings and the "O" has 13. :: fd
