1 - 20 of 41 Posts
Hi,
I just purchased a new Mustang project, and the car has what I was told was a 302 motor in it. I don't know any of the details about the motor, so I'd love to start tracking down all the information about the engine as possible. I'm uncertain where to find the block casting number to indicate the year it was made, or any other details. Can I get a little help?
751588
The block will have a casting number on the right side (it's hidden behind the starter). Since (I believe) the 289s and 302s use the same basic block, that may not give you a positive answer. There should be a build date stamped onto a machined spot on the block just ahead of the left head which will give you some more info (again not a positive). The 302 heads used to have a cast "302" on the top of the heads. With all the engine rebuilds/swaps it'll be really difficult to tell for sure.
Look up under your starter, There will be a date code, You might have to pull to read it. Should be C80E- 6015-A or B for a 302
uh huh... well, pull the starter motor to write down the casting numbers you see above it on the block, front drivers side of the block right in front of the cyl head on the little ledge should be a stamped code, pull a valve cover, actually both, and see what kind of stamping numbers are there. you can then use google to get to cross-reference charts..or take good photos and come repost...there may be a small tag on the carb, on the side of the distributor will be some stamping numbers, a stamping number on the intake, and on the back of the block at the edge of the intake manifold, you may see a partial vin number stamped in the ledge...might be yours :)
Discussion Starter #8
I'm still having a hard time finding any numbers. Am I looking for the numbers on a horizontal surface, or rear of the engine on a vertical surface. Here's what I'm seeing at the rear of the engine from the top view:
751599
1967 Mustang Convertible
From the bottom up. You have to look on the passenger side, bottom of the car. Look up past the starter and you should see some casting codes.
The intake shows C8DE so its a 68 Intake, more then likely. If the block matches I would say 68 302 but have to get the casting codes of the block.
February 25, 1970 351W.
It was created for that Fairlane/Torino line but can be used in any Ford Vehicle that had a 351W including the Mustang. Verified since I do see 8 intake bolts on one side, so you have 16 intake bolts vs the 302/289 with 12. That would be a nice surprise for me. :) More cubes.
Date code is 0B25 - so 1970 February 25th.
@Huskinhano you had this in the thread about resistor wires
Huskinhano
Joined Mar 6, 2001
#11 a moment ago
Looks like a 289 block. Just behind the intake manifold, on the block between the two upper bellhousing bolts is a depression in the block. If it goes between the two bolts, it's a 288. If the driver's side is filled in half way with the depression on the other half, it's a 302 block. Functionality there isn't really anything different between a 289 and 302
Discussion Starter #16 (Edited)
Very interesting. So - does that mean the engine came in a 1969 model car?
My plan for my Mustang doesn't involve using this engine or the manual 3 speed. Any insight into what the engine/trans combo is worth? Is it considered desirable?
a used running, nothing special,289/302 is about 500 bucks 4 speed toploader maybe 700-900
So - it' not a 302, it's a 351W?
The "C9" indicate 1969?
Does the "O" in the C9OE mean it's from a 1969 Fairlane or Torino?
Yes, C9OE-B is a 351W.
The "O" in C9OE only means that the Intermediate Group (Fairlane/Torino) was responsible for that particular block casting mold... the block would be used across the Ford/Mercury line as needed.
My plan for my Mustang doesn't involve using this engine or the manual 4 speed. Any insight into what the engine/trans combo is worth? Is it considered desirable?
No, it means that the block was DESIGNED, initially, for the '69 model year. Yours was actually cast in February of 1970. A partial VIN on the top rear of the block will tell you at which assembly plant to potentially narrow it down a bit to what it was originally installed in.
Classic, so, you have a 351W, and a toploader ? And you're NOT going to use them ??! The 351W is well though of, and the toploaders are great. What are you thinking of instead ? LSG
1 - 20 of 41 Posts
