1 - 2 of 2 Posts
closed chamber heads with 2 barrel size ports and valves, boost the compression on that 351 c 2v engine or increse the low end torque of that 4v headed engine. make a 351m or 400 a power house with these heads. these heads are bare castings, use your 2v valve train. also have a 351C 4v intake with 2v port size to use with these heads or i have a 4 barrel intake for a 351m/400 using these heads. $400.00 for the heads and your choice of intakes. 325.00 just for the heads
How well do 2v valves work in te 4v closed heads? Will there be a difference between using the valves that may have come with the heads originaly and the valves from my 2v heads?
1 - 2 of 2 Posts
