The starter cable strap that came on the original cable has a twist in it. Is this correct and if so can someone indicate where it fastens? Thanks..John
EDIT: Initially, I had that bracket connected to the motor mount pin, but now it's connected to a wing on the engine block. As I recall, I did some research and determined that's the correct location. Here's a picture. It's hard to make out, but maybe it will help.
The negative battery cable also connects there.
748803
Thanks Klutch. That would be the reason for the twist it it as well.
I just put the ground strap on so I'll remove and put both on that "ear" together. I'm assuming only 1 strap?
Thanks! ?
As I understand it, all but the earliest 1970 Mustangs had a built-in grommet in the negative battery cable which bolted to the fender apron. I ordered the "Heavy Duty" cables from NPD which don't have that grommet. That's why it's connected where it its.
The "concours" set I purchased had a built in attachment strap to attach it at the voltage regulator screw and it looks correct. The starter cable had nothing so I removed the strap from the old original cable and put it o the new one.
