I got the word from the machine shop today they said I have to go .040' over to clean up the cylinders. The machinist said that a 351 cleveland should not be bored more than .030'. So my question is has anybody that bored their cleveland 040" over had any problems cracking the cylinder wall. I did read on a cleveland site today that it can go up to .125" max bore, which seems like quiet a lot to me.
Just looking for some peace of mind. Thanks.
Clevelands are sorta famous for the blocks being of unreliable thickness, so you can't really bet the farm on it being thick enough. The only really reliable way to go about it is to have the block sonic checked and see what it will safely bore to with metal left over to prevent any issues.
I won a special award
As I stated in your other thread about this issue, have the block sonic checked. If it's thick enough, you can go .040 over.
One of mine is .060" over and is fine. Another is .040" over and it is fine. The last is .030" over and so far so good. I haven't ever had an issue with mine, but a sonic check sounds like cheap insurance prior to investing a bunch into machining and parts only to have it come apart later.
Mine is .060" also with no problems.
jsgarron said:
What's considered thick enough(Dim)?
I can't remember what the minimum that is considered safe as it's been around 20 years since I last played with 351c's. A good machine shop should know.
