Ford Mustang fastback GT390
Just thought I’d post a pic of a blown head gasket in my 351c a couple of years ago, just wondering what would have caused it. I bought the car knowing that something was wrong, it was blowing huge amounts of smoke out of the oil & breather caps, at worst I thought it was piston rings, any one out there had a head gasket blown like this. ??
Maybe the intake was over tightened. The intake manifold bolts are at a angle to the intake manifold side of the head. When you tighten the intake bolts they tend to act like a wedge lifting the top part of the head off the block. For performance use it's common to tighten the top row of bolts about another 10 pounds as I recall to counter the effect. I'm not saying this was the cause in your case but could have
Every blown head gasket I've seen was blown in the narrowest part of the gasket between 2 adjacent cylinders.
@awhtx yeah I had one do that between #7 and #8 , and on the 289 / old 302 firing order that makes for a ROUGH running engine. I have also seen them blow near a cooling passage that made boat-load of steam in the exhaust, or between a cylinder bore and the exhaust crossover...What a racket !!
Yeah, I thought head gaskets mostly went on the cooling passages, I was just glad it wasn’t something more serious, a cheap fix.
