So i checked out the rods, I have a flat top piston with valve reliefs that will give me a 9.5-1 compression ratio. I checked number 5 piston assembly If i put 5 on with 1 then the chamfer will face the other rod, is this going to be a problem, Pistons are marked with with a number h555, machine shop owner wasn't in today so I don't know the make of the piston. I read that the chamfered end of the rod should always face the crank journal? So if a 1 goes with 5 then 5 must have its piston put on 180 degress out.
