Hey All,
I have swapped out a 4sp for an AOD on my 351C. The AOD was from an '85 5.0L. I'm fairly certain I installed a 28oz flex plate (unless it was mismarked). The problem I have is that there is a very noticeable vibration now. Does the flex plate need to be 'aligned' a certain way or can it just be mounted with the weight in any position? Thanks and Blessings.
No, you can not put the flexplate on wrong. The bolt holes will only line up one way. I have a picture around that compares the 50oz vs 28oz. I will look for it.
Hey 70_Cougar - Thanks for the info. I'll pull the inspection plate and see if I can tell what's on there.
