I’m hoping I get constructive feedback on this forum vs. others I tried.
I think I am doing the right thing, but I want more eyes on it. Here’s what I’m doing:
This is my first ground up engine build. The rest of my experience has been with stock components. Never even had machine work done before. I want to get as much as I can out of my parts safely. I’m leaning to the 72cc chamber and cam to match, but… if… but… if…. You know how it goes. Any opinions?
- 1970 Mustang with full interior. This is first a good weather daily driver. We will do some drag racing with it, but for fun and not competitively. Pump gas capable
- Toploader 4 speed with between 3.50 and 3.89 gears out back
- 351C engine with flattop pistons, stock stroke, and zero deck. Quench height at or below 0.041”. Zero deck via shaving the deck or ordering the right comp height pistons
- Edelbrock Air Gap intake, or Performer intake if the Air Gap won’t fit under the shaker.
- Holley mechanical secondary carburetor
- Hydraulic roller camshaft
- Trick Flow 195cc aluminum heads
- 72cc heads yield a 9.8:1 static compression ratio. The highest effective (dynamic) compression ratio I can get is around 8.0:1 with a cam that closes intake at 61 degrees. Cam would max out at 6000, which is fine by us.
- 62cc heads yield 10.9:1 static compression ratio. The lowest effective compression ratio I can manage would be around 8.3:1 with a cam that closes the intake at 69 and operates (mostly) below 6500.
