Not sure of the pan capacity by itself, but a 351C ('71 variety) holds 5 qts (I'm sure that it's less than that since all the oil doesn't completely drain on an oil change).
Sidewinder is correct.You can run 6 quarts in the stock pan if you want.If you are not running the engine hard just run 5.My.02.FastE
