Ditto...bighorse said:I'll get the "It's your car and you should do what you want" crap out of the way, and then ask why in the world would you want to do this? A 70 Mach is a very desirable car, the Cleveland gives a very good power to weight ratio, and a 429 would detract from its value. Just my $.02.
Hemikiller said:Ditto...bighorse said:I'll get the "It's your car and you should do what you want" crap out of the way, and then ask why in the world would you want to do this? A 70 Mach is a very desirable car, the Cleveland gives a very good power to weight ratio, and a 429 would detract from its value. Just my $.02.
If you want more power, take the money you would drop on the 429 installation and make a stroker (408) out of the 351 Cleveland. Same power level, less weight, stock look, no crappy aftermarket swap parts to install.
Besides, a 429 is a mofo to work on in a 70.....
What's wrong with Speedomotive? They were great with my parts. I had no complaints at all with their service.dodgestang said:Stay far away from Speedomotive out in CA
But how long until IT needs a rebuild? :thumbup: / :thumbdown:Reverb said:That site doesn't work.
The only reason I wanted the 429 was that it was going to cost me 650 and that was with the C6.
The faxed the wrong head cc specs to ross who then made the piston to the incorrect specs so my compression was off. I ended up eating all the costs and they refused to even replace the piston with correctly milled pistons. I'm sure they are a great company to work with when everything goes right but they have piss poor customer service and are real arsehats on the phone and in general when they screw up.Rickmaan said:What's wrong with Speedomotive? They were great with my parts. I had no complaints at all with their service.dodgestang said:Stay far away from Speedomotive out in CA
