Hey: I recently pulled a 351w out of a 68 FB and was curious about it. the casting numbers are:
D4AE-6015-AA 4
http://users.zoominternet.net/~Natedogg01/casting.jpg
With the smaller numbers in the lower corner being 4K28.
There is old ford blue block paint on it... underneath the coat of black. Which would lead me to believe it is early but you can never be sure :p
Any help with telling what 351w this is would be greatly appreciated. Early/Late. anything...etc.
1974 block built on 28-NOV-1974.
You can look HERE for more information.
holy cow! thanks man!
I woulda never known.
Thanks for the link, very useful information!
Just some guy
This is also a "heavy" block. In 1975 the 351W's lost about ten pounds of cast iron weight. Unfortunately it came from around the main bearing webs where it added some strength. While they may not compare to a late model "MotorSport" or "Sportsman" block, these blocks are still popular with folks planning on using superchargers, nitrous, or (ahem) turbochargers.
wow that is a good thing to know, thanks for the input Gypsy!
thats a strong early block 1974 as others have said. check the bore if your lucky, it might be stock bore too!.
what are you replacing it with?
Discussion Starter #8
I'm going to keep it... I just wondered where in the years it came from. I do know that it is the standard bore size. Im leaning toward a 408stroker kit though.
