If those are the rear passages that's what they'll look like as they're blocked off by the gasket. "Rear" passages only exist so that the heads can be used on either side. Now, the "crud" looks to be the result of mineral deposits in the coolant and I'd strongly recommend those heads be "tanked". If you have the engine on a stand, I'd pull the block drains, then reinstall, plug the inlets in the front of the block (use a piece of scrap metal or plastic with some RTV to seal) and fill the water jackets with solution of citric acid boiler cleaner and let it "work" then pull the block drains and flush everything. Some Vaseline on top of the block and plastic sheeting or trash bag material to protect the cylinders would be a good idea. Repeat until the "crap" is gone.Day 3: Got the motor pulled apart. Figured out why I was having cooling issues. 2 of the ports were completely blocked off, the other 2 looked like the 2nd pic. Guess I probably didn’t need that new 24” radiator with dual fans I bought after all. Oh well, it’s getting installed anyway. View attachment 775891
