Any one know how far you can safely cut a 351w crank. The one in my coupe was cut to 10 under on the rods, and 20 under on the mains. I am doing anouther rebuild on it and there is a little scoring.[not a lot, tiny bit] can this be cut more? I know the mains are huge for the size of the motor, but is 30 under to much? Or should I be looking for a new crank.
Im not sure on the limit, and I may be wrong, buy I have only seen oversized bearings up to .20 over.
Although it's not commonplace now with the proliferation of stroker cranks, in the past I've seen W cranks have the rod journals offset ground from the stock 2.311" size to 2.125" to increase the stroke by 3/8". I can't recall the size but builders once ground them to SBC sizes too, in that general range, to use Chevy rods...
.030 should be no problem, strength-wise...W's have big journals; 3.00" on the mains and 2.311" on the rods. As a comparison, the Cleveland crank has 2.749" mains and 2.311" rods.
IME, the critical factor, at least in racing apps, is ensuring adequate oil flow to cool the bearings at high speed. I open up the bearing clearances (actually, the crank grinding vendor does it to my specs) to allow more oil to flow through the bearing spaces.
In your application, I anticipate no problems whatsoever...
