The video/audio quality is not the greatest, but that sounds like rod knock to me. Hopefully i'm wrong.
I also hope you are wrong lol. Whats the easiest way to determine rod knock? Remove the oil pan and look for discoloration or a loose rod?The video/audio quality is not the greatest, but that sounds like rod knock to me. Hopefully i'm wrong.
Could you explain why I would check the fuel pump? Very curious what on the fuel pump would cause this.If it's not suddenly running rough you can probably skip the valve-train check. Sound quality isn't great in videos but I'd check the fuel pump first. If you raise the engine speed slightly and then suddenly close the throttle and the noise momentarily goes away, then I'd pull the pan and check the rod bearings and, if they are okay, look for a bad wrist pin or broken piston skirt.
The actuating lever on the fuel pump is spring loaded so that after it is moved by the eccentric on the front of the cam sprocket it returns to an "at rest" position. If the spring loses tension, breaks or there is some other issue preventing the lever from returning it will smack against the eccentric and make a tapping noise like a collapsed lifter.Could you explain why I would check the fuel pump? Very curious what on the fuel pump would cause this.
Definitely not an exhaust leak. After I shut it down, there was very random, loud knocking/ticking noises coming from the engine. It will also not stay idling any longer which makes me think it is more valve train related. I could be wrong though.exhaust leak?
If it's making noise AFTER the engine stops rotating then it's most likely HEAT related...Definitely not an exhaust leak. After I shut it down, there was very random, loud knocking/ticking noises coming from the engine. It will also not stay idling any longer which makes me think it is more valve train related. I could be wrong though.
When I say shut it down, I meant after the 6,000 rpm run. I turned off the engine, came to a stop, and restarted the engine. With the engine idling is where it started making the random knocking/ticking. Sorry for the confusion.If it's making noise AFTER the engine stops rotating then it's most likely HEAT related...
