I just built a 408 stroker and my oil pressure flutters very quickly once it warms up. It goes from 38-44 very quickly. When cold it stays at 65. I’ve never had a fluttering problem before and was woundering what it could be or if it’s a concern. When cruising 1500-2000rpms oil pressure stays at a constant 50psi no fluttering. It only happens at idle. This is a freshly built motor with about 40 miles on it. Any thoughts? I’m using 10w-30 Right now with bearing clearences being .002 for mains and .0025 for rods. Has a mechanical gauge, also used my friends new gauge and did the same thing. Thank you
68 Mustang Coupe
I'm not sure I'd be concerned about a 6 psi swing with decent pressures like that.
65 Fastback 289 4 spd, 65 convertible 5.0L 5 spd. 3.73 8.8
I wouldn't worry about that, it has oil psi. What brand of oil pump? timing chain slack at idle?
It could be your gauge. I have an electrical oil pressure gauge in my white 66FB and it flutters at idle only. I have a mechanical gauge in the 66FB project I’m working on and it is pretty steady at idle and at speed.
My 408 did the same thing. It's got about 3,000 miles on it now and seems to have leveled out. I broke it in with Brad Penn break in oil, then switched to the zinc added 10w40 oil.
