Hey Folks,
So here we go . . . I have a 1965 Mustang Coupe. It came with a 351 which was mated to a toploader that needed a rebuild. A couple of years ago, I purchased a used 1993 Cobra T5 to put in it. So finally this summer, I got it to one of my mechanics and he put the T5 in. I supplied a new Flywheel (28oz, 157 teeth) and clutch. The Driveshaft was cut accordingly. The cross-member I used, I bought from a guy down in New Hampshire through Ebay. The crossmember was built by this guy, and reviews were positive.
When I picked up the car, I pulled out of the mechanics driveway, and something was NOT right. as the RPMs went up, it would shake and get worse. The first thing that popped into my head was the flywheel is wrong. And, it was. So I ordered a 50oz flywheel, and that was put in. The shaking was better, but still present. I got on this forum and saw somebody recommended new dowel pins, so we did that, because the old dowel pins were pad. That also helped a little bit, but still shaking. One of the Engine mounts was also bad so replaced that.
This Thursday my mechanic is putting the car on the lift to carefully watch the drivetrain under acceleration to watch the drivetrain, and see if he can see what externally might be unbalanced (Like the Drive shaft).
This all being said, I am also concerned the crank got messed up from driving (Although not far) with the 28oz flywheel as I know this can happen (God help me if that is the case). The other thing could be that since the T5 was used (I bought from prestige Mustang in Georgia) perhaps that was damaged previously and this is something internal with the T5. The car did not shake like this with the top loader.
So here are some questions:
1. It looks to me like it's fine to mate a T5 to a 351 (No I don;t know if the 351 is modified. There was no Information on it.) Please confirm if that is correct, and advise of any caveats.
2. I have heard that if rear gears are even the slightest chipped, that can cause shaking.
Not sure what other things to check, and my mechanic is not sure what else to do here.
If anyone has some sort of check list, or suggestions, I am desperate and would gladly welcome the help.
Thanks for the assistance on this.
