I don't see the "S" on the intake... the casting number is C7 9425A. Here is a picture of the underside of the intake.As stated in Ford casting books, a 1966-1968 390 GT has a large "S" casting mark on intake runner next to casting number.
Does yours have that?
What is your casting numbers?
Can you get the letters after "C7xx-?Here's a chart of intake part numbers: https://www.carmemories.com/cgi-bin/viewexperience.cgi?experience_id=587
And a picture with the big "S" on the manifold.
I'll supply some chart info. Guessing it's a 427 intake???
No. That looks like a C7JE-A marine intake used on a 427. Small port and not drilled for the 390 "GT" style PCV system. With tongue-in-cheek being a marine piece, it's a "boat anchor". LOL.I found a period correct 4 barrel intake manifold on craigslist that came off a 1968 Century Resorter boat motor. Is this the same intake used on the car motors?
Good to know...I already have enough "boat anchors" to supply the Pacific Fleet.No. That looks like a C7JE-A marine intake used on a 427. Small port and not drilled for the 390 "GT" style PCV system. With tongue-in-cheek being a marine piece, it's a "boat anchor". LOL.
I bought a 390 out of a 1968 Galaxie. It has a 2 barrel manifold. If possible, I want to find a period correct 4 barrel intake for that motor. I'm putting it a 68 fastback "C" code. My goal is to build a Bullitt clone.Are you planning to use it on a car motor? If so, why? Besides the weight mentioned earlier, it is not a particularly high performance upgrade. If your goal is to optimize engine power, get a hold of Jay Brown's book on FE intakes. He actually has a dyno in his home shop and systematically compared the flow of a number of different intakes and provides data and analysis for the average consumer.
^+ I'm not sure what a "period correct" iron manifold costs, but any used aluminum manifold would be an improvement in performance plus a large weigh savings.I would just go with an aluminum intake and paint it the same as the engine. If you grind off the name most folks won't even notice it. I did that with an Edelbrock on my wifes 289....yes dear, pretty much all stock, just like you wanted....![]()
