Trying to install exhaust spacer on my 67 390 automatic. I can't figure out which is the right way to install i.e. right side up.
Anyone have a pic of a spacer or heat riser installed? Thanks
http://i379.photobucket.com/albums/oo235/67gtrag/motor%20install/67390motorinstall109002.jpg
Not the best pic but maybe this will help.
Counterweight to the blockside.
Thanks - what side is the actual heat coil on? If it is just a spacer, what side has the flat side on? hope this makes sense.
If I understand you correctly I would say the "coil" you are talking about goes to the block side and the "flat side" will mate up with the exhaust manifold. A donut gasket will then go between the spacer and the h pipe.
