1 - 12 of 12 Posts
Scored a 6V set up for the 390 that’s going in the 67 S code convert I’m getting ready to restore. It’s the Galaxie set up with the tiered carb pads. Anyone running one of these? Any issues I should know about that would be helpful?
They run real well with just a good rebuild. Look for worn shafts in the carbs. Recommend blocking the exhaust crossover, Mr Gasket gaskets should do so, you'll need the taller low riser port gasket. All heads will work, but some are better than others
If you are running a 67, it'll bolt to a C7AE-A head fine, but there will be some port mismatch. Doesn't really hurt anything, but the C7AE-A and C8AE-H are pretty much corks to even the mildest FE. If you are running an early head or a C6AE-R, they match better, and the heads flow a bit better.
Once you get it in the car, anything you can do to increase plenum volume helps power. Based on air cleaner, buying or making some insulating spacers will help the top end a bit.
Of course, make sure you are getting full throttle using your foot, sometimes Mustang linkage can be fussy and you may need to work your design to get full throw
Should be fun!
It's a setup that's a blast to drive.
I had my Ford aluminum intake powder coated, holds up to any gas leaks in time.
Great you got the Galaxie setup, because the T-Bird setup carbs diff height, won't work. These were a "dealer option".
At work now, from home I can post some tri-power info links.
My orig carbs, bowls warped, junk. So found Carl's Ford Power Parts had exclusive deal with Holley and sells re-engineered carbs. Three 300 CFM's IIRC.
Did you get the unique air cleaner & all linkage?
Big note ... since this setup doesn't support any "ported vacuum" for the dist, I had to find the correct 390 dual point mechanical advance dist.
For the 2nd oil fill tube on this intake which I didn't like, I had my engine builder press a freeze plug into tube opening.
Also to fit a t-stat into the large opening, I made an aluminum plate to hold t-stat in the housing. Often these intakes used a puke tank, is why larger opening.
I had engine builder select a mild Comp Cam to match this set up. He used a "Desk Top Dyno" program.
Once built, I had the engine run on a dyno 1st, then did chassis dyno to pick correct jets for carbs.
Got my linkage and large vacuum tree for power disc brake hose at Carlisle Ford Nationals.
I did use electric choke on center carb.
I am using Edlebrock Performer RPM heads.
Have fun. Mines been running 13 yrs.
Get on it to much, note you'll have to change your oil a bit more often. You dump a lot of fuel when on it. Normal driving on just one center 300 cfm carb is just fine too.
Linkage is all there and all hooked up. Fuel rail is there. Carbs were gone through recently according to the guy I got the set up from and they do look fresh. It’ll be a while before I get to run it. The car and engine are all torn apart.
Good that Engine apart. If you're gonna keep tri-power on engine, this is the time to select a cam that will work with that setup..
I know this thread is a bit old but I was just wondering what distributor I should look for? I was just reading the thread again and I must not have noticed the part about the no vacuum. And curious what cam you went with. Gathering parts as always. Never ending but I like hunting for stuff.
Carguytroy, that is a nice setup. You will pass everything except the gas station in that beauty. As far as distributor I’d look into the MSD billet with a black cap. I don’t have experience with the tri power but that is a nice distributor. Maybe someone else will chime in.
Hi, let me look tonight thru my Ford casting book if I can't read #'s off my dist. as well as my cam card.
Ok, looked thru my Ford Castings book for 60's cars.
Since numbers on my dist are on the back can't read, here's what I believe I used: C2SF-12127-B.
It's a dual point mechanical advance dist for tri-power. See my attachment.
As for cam, working with my engine builder we used a Comp Cam, mild lift, think 272, can't find my cam card at moment. You don't want a wild cam or it'll just dump to much gas into engine, not good.
As for highway mileage, got ~ 16 mpg just cruzing from PA - NH.
But city, yea not great, I go out to local car show and back and use ~ 1/4 tank.
But I didn't want a "great gas mileage car".
I wanted one with a real "WOW" factor. blast to drive.
Also note, you have two oil fill spots, one regular one on valve cover, 2nd now on tri-power intake. I had my builder put a freeze plug in filler hole on intake, looks clean. No two filler spots.
I believe I ran into a VMF member at this year's Fabulous Fords Forever at Anaheim Stadium and he was running a tri-power setup on his 390. If he sees this, perhaps he can chime in. He liked it and had no complaints.
Discussion Starter #12
Thanks for the info. Checked out eBay for a distributor. Nothing as of yet. Probably gonna take a while to dig one up but I’m not in a hurry. Hunting for parts is fun to me.
1 - 12 of 12 Posts
