Plus acual shipping costs from Houston. This unit is guarranteed to be right. No noise or klunk.28 spline. Ready to be installed. Price is firm.THANKS SCOTT 936-648-8599
I'm not much of a rear-end guy. What would need to be done to swap into my 8" rear? I guess I need to know how complete is the setup you are selling. R&P with clutches or whole chunk? Will I need to take it to a shop to be "set up"?
You have 4 9/16 bolts holding in your axels on each side just pull the brake drums and take out the bolts.Pull your axels out about 10 inches.Then take the drive shaft out.Remove the nuts holding your "pumkin" in (watch out it's gonna gush old rear end oil) take out your pumkin and put this one in. Of coarse clean the gasket surfaces and install a new gasket with a VERY small amount of sealer.Reverse procedure add 90wt gear oil with limited slip additive and go on!!!!!!Here at my shop about 35 min.THANKS SCOTT
P.S. as I said this unit is ready to go!!!!!
