·I had a closer look, and it seems that the cover for the secondary diaphragm is warped, so it isn't sitting flat against the carb. and therefore not creating a seal on the diaphragm. Basically when the cover is bolted on I can actually see a gap through the assembly. Unless my logic is way off base, without a seal, I get no vacuum, and without a vacuum, I get nothing.
I think I'll try to just make a custom gasket rather than attempt to un-warp the cover and see where that leads. I assume there is something in the guts of the carb. that would allow the vacuum to release?
