I've got a '65 289 that was orignially a 3 spd and someone put a 4-spd toploader in it. The input shaft of the transmission growls when the car is in N and you let out the clutch. I dropped the tranny and the input shaft also feels rough when you spin it.
My question: can you replace the input shaft bearing w/o tearing the whole transmission apart? Has anyone done this? There is a part that fits over the input shaft and has 4 bolts hoding it to the tranny case. If I take that off, can I slide the whole input shaft assembly out without dropping needle bearings or similar inside the case?
Yes!
Remove the front bearing retainer (4 bolts), tailhousing, you will have to drop the cluster gear to the bottom of the case with a dummy cluster shaft, then the input and the bearing can be slipped out. Be careful, rollers in the rear of the input!
Fashon a dummy cluster shaft from a 7/8"diameter wooden dowel, 8 3/4" long. Push out the cluster shaft with the wooden dowel from front to back.
A dummy cluster shaft is needed so the needle bearings will stay in the cluster gear.
