21 - 22 of 22 Posts
Discussion Starter #21
I believe it was honed,,,, it was not driven at 60 over. But like i said I am not too stressed, I just found another 351 block that is 40 over that has already been magnafluxed for $200. SO i will pray for the best and prepare for the worst.
I will start a build thread i always wanted to do that. in case I havent said it thanks for all of the info. Im excited
So far i have the block the crank and now the rods. Now i just need the pistons and rings and I can start the build
Sounds like you should be ok. Just make sure you have enough clearance for the pistons. You're not building an all out racing engine so I would more than likely do the same if I had come across the parts cheap enough.
21 - 22 of 22 Posts
