1 - 20 of 31 Posts
The '68 managed to get some dyno time today.
Closest guess to the HP and torque numbers wins a virtual high five.
Build:
428 FE
10.5:1 compression
.030 over forged pistons (can't remember brand, they're old)
Stock crank/rods
Edelbrock RPM aluminum heads w/oil restrictors
Edelbrock RPM aluminum intake
Holley 750 HP double pumper
Pertronix III distributor and coil
Lunati Voodoo hydraulic roller cam (Lift: .559/.559 Duration @ .050: 211/219 LSA: 112 RPM Range: 1600-5600)
Lunati hydraulic roller lifters
Hardland Sharp roller rockers (1.6 ratio)
Edelbrock aluminum water pump
Factory 7 blade CJ mechanical fan w/clutch
Factory power steering
4 speed toploader
Mcleod flywheel/clutch
9" w/ 3.25 open gears
This pull was done to 5500, the final power pull was done to 6000 RPM.
IMG_1953 by armon7, on Flickr
1967 Mustang Convertible
401 RWHP and 420lb-ft
Reactions: rose62
I'm gonna guess 570 lb-ft, and 570 HP (probably holds it there from about 5600-5900 with that cam, I'm guessing). 530 to the rear tires? =)
410 RWHP 425 lb-ft
Lol that’s 300. Are you trying to have it both ways?
I’ll say 333hp at the wheels
Doh, brain fart...fixed. I came back to fix my error and you had to go and quote me. :)
If I over guessed at 401 RWHP, I will say 385 RWHP and 410lb-ft. Maybe you can give us a warmer or colder help. :)
I want to see the chart, not just max number … please. (for future reference).
1 - 20 of 31 Posts
