1 - 10 of 10 Posts
before i start this fiasco i've got a 66 mustang w/o engine and a 429 laying on the ground . short of sliceing up the engine compartment does anybody know if there is a way of straight bolting it in and what parts are needed
No. The 429 fits, just barely, in the 67-70. (The 71 was built for it, of course).
To get a Lima engine into a 65-66 will require major chopping and modification.
I won a special award
Ditto
A freinf of mine did it, he took a front clip from a 67 and put it on his 65 fastback,worked at real nice,he wound up putting a 460 into it,the biggest problem was the headers,he got them from Kooks on long Island,he actually has a boss 429 he's contemplating putting in but then he has to do the towers like his original Boss 429
Well, aside from requiring massive surgery on the car and making the car vastly nose-heavy...
A 351W will fit, just barely, or a GM LS-family motor, and either one can be built out to close to (or a bit over, in the GM motor) 7 liters if you want to spend the money and really think the car needs that much motor.
Blasphemy!
put a set of 68-70 shock towers in it and it will fit. FPA makes the headers. i take it the car is for drag racing so i'd stroke it to 514 c.i.
Discussion Starter #9
thanks for the feedback nobody said anything about mounts or change of oilpan justshocktower problem is that it
Here is a link for installing one in 67-70, there are several mod's to consider:
rev-460in69.htm
1 - 10 of 10 Posts
