1 - 12 of 12 Posts
Hey guys im makeing a 302 to 429 swap in my 70 mustang fastback in a couple of weeks and i am wondering where to get a bellhouseing to be able to use the 429 with the C-4 and is there anything in the C-4 that i can beef up so it can take the abuse ?? or is it just plain better to go ahead and get a C-6 ? i would like to keep the C-4 for a little bit cause i just recently had it rebuilt. but any suggestions would be helpful.
Discussion Starter · #2 ·
ohh yeah and i forgot to mintion that it is pretty much going to be a stock 429 except (headers,flowmasters,mild cam, edelbrock performer intake and 600 carb.) thanks
well.. you can, but i would suggest a mild c6 instead, it would fit the app better i think. Use the fresh c4 as bartering material or something instead of trashing it.
Ya, eaven a mild 429 will be a bit much for a c4. You could build one to surive, and they do sell adapers, but by the time you do that, you will have spent more money then just getting a good c6. Also it may just be a stock 429 now, but what happands a year or two down the road when you want to build it up a bit?
Unless you want to spend a lot of money to get the C4 built for the torque, forget it....Go with a C6....But, you can use a bell housing from a 351 Cleveland to bolt the C4 to the 460....
Also, you need to rethink the choise of your carberator. The 600 will thirst the 460 to death....Need at least a 750 double pumper, or an 850....The 460 is a thirsty devil, but, you also need the bigger carb just to get enough air for the motor to breath.....
Trust me, you will love the swap....Big Bilcks Rule the World.....
An adpater plate from 1/2" aluminum is fairly easy to make...the 385 series engines have a similar looking bolt pattern, just bigger.
The converter/flywheel might need some attention to adapt the crank pilot/BC
Main problem is building the C4 to handle the low-rpm torque of the big block. Aftermarket input shaft (later large diameter unit - 26 spline) as well as overruning clutch and some drum upgrades would be required.
Since your 70 will easily take a C6 in the tunnel, I'd suggest getting one. The 385 C6's are plentiful, inexpensive and durable, albeit with a weight and parasitic loss exceeding that of a C4. Save the C4 for another small block project...they're nice to have around..*G*
Also, I have gone thru the swap in the last few months. If I can help yoiu with any problems, let me know....
My e-mail is in my profile......
Steve
Look around for a 351M/C4 bellhousing, blockplate, flywheel (flexplate), and torque converter. They came in mid-70's Torinos, LTD II's, Tbirds, etc.
Use a "H" intermediate servo/piston from a truck C5, shift kit....
Much less rotating mass in a C-4, should work well behind your mild 429...
351C bellhousings are the small block pattern...Won't fit 429/460 engines.
That is correct, The 351C bell Housing WILL NOT WORK!.
How do I know? I had a 351C in the FBD before I put the 429 in.
Discussion Starter · #11 ·
First, unless you have EXPERIENCE with a C-4 & a 460, please don't steer people in the wrong direction. He'll have much more room to say the least. First, ALL 400's & 351M's share the same trans bolt pattern with a 429/460. Second, you DO NOT need an adapter as there are always bellhousings for sale... ask me! Third, Trust me you'll NOT need a C-6! Fourth, I usuallu use an 850 on STOCK engines! Fifth again, a 429/460 is NOT too much for a C-4. I would barter a C-6 to get a C-4 any day. Now... my experience. First, '71 Grande, 377 hp 429SCJ, C-4 from a '77 T-bird, no re-build, 10" converter. 12 flat & ran for 150 passes until I put mu Spoiler back together. Second Stock 360 HP 460 in the same car, drove it like I stole it until I sold it.. still works. Third, 8 second '66 Mustang, 1.21 60' well over 1000 hp on the bottle. Yes it's a race version but I can show you how to build a C-4 to take 700/800 HP reliably for chump change & it'll live as long as any C-6 out there. Don't take this wrong guys, I'm not flaming anyone. I may not agree with what you say but I'll defend to the death your right to say it. I have 15 years of transmission experience & trust me, I know what I'm talking about.
http://www.tulsahotrods.com/ Check out the drag car if ya wanna!
I agree 100%!
I'm running a pretty much stock 68 C-4 behind a 392W that last ran a 12:71ET in a 68 Cougar. Modifictions include;
"H" servo
B&M shift kit
Auxillary transmission cooler
1 - 12 of 12 Posts
