I have 66' 200ci 6cly with a non-adjustable rocker arm assembly. I torqued the rocker arm shaft to specs but am still hearing lifter noise. According to the manual, I need a Ford tool (#6513-K) to check value clearance. Where can I get one of these tools? Is there another way to check it?
I can't help you with the tool but I do have some thoughts on the subject. As you already know, the rockers are non-adjustable. Any adjustment is accomplished through the use of a longer push rod. IMO, I would start by removing the rocker assembly and pulling the push rods to check if they are bent. I had a similar situation with my 66 and found that some of the push rods were bent. I wound up changing the push rods and lifters (easy process and inexpensive).
Scott
To check if a push rod is bent, roll it on a flat surface and you will see the bend.
Try to isolate it before disassembly. That will help in any ultimate "fix" of the problem. The best surface I've found to check the pushrods with is a piece of glass. If you don't have that handy, your wife's coffee table is usually a good surface! Do this at your own risk... :lol:
