1 - 11 of 11 Posts
This idea popped into my head this afternoon after watching some videos of a 2011 Mustang w/ the 6 speed automatic running a 9.95 quarter mile time on stock internals.
Does anyone think the 6R80 could easily be bolted up to a Fox Body 5.0? I'm sure it will be an easy transmission to find in a junked 2011 eventually.
Since the bell is integral to the case, no.
are there other auto transmissions that will bolt up other than just a 4 speed auto or AOD / AODE ? I'd like a 5 or 6 speed auto in my 68 also :)
How about a 5R55(S,N or W)?
Performance Automatic - Pro Fit Bellhousings
Bauman sells a stand-alone electronic controller for these. It certainly wouldn't be an inexpensive swap though. By the way, these have fantastic ratios for a street car: For instance, the 5R55W - 3.22, 2.41, 1.55, 1.00 and 0.75 in overdrive. (With a typical rear gear of 3.0 you'd have approximately the same final drive as C-4 backed by a 3.90 rear!)
Any new info on this stuff? 6R80 or 5r55S,N, or W Has anyone done this? My question is if the 6r80 mounts are the same as the Coyote?
Who is it that has 6 speed automatics in the aftermarket, TCI? They use the GM trans with their own adapter bellhousing and stand alone controller. That's what I would do. Pretty much plug and play.Let some one else do the engineering to make it work.
As Huskinhano says, you can check these guys out: Transmission Packages - TCI® Auto.
Just click on the "6X Six-Speed" tab and then "Ford"
I have no experience with these guys as I am running a 6-speed manual at the moment but have been playing with the thought of going 6-speed auto
I appreciate the 2nd overdriven gear in my 2014 Explorer. It's a big heavy chunk, theecoboost engine has a relatively narrow power band and I'm putting several hundred gallons of gas through it a year.
I just would see less of an advantage to a second overdriven gear in a "fun" car. I really appreciate having overdrive in my '65 (4R70W)...and the electronic control is nice, but I don't think the second overdriven gear would be a huge improvement for me.
I guess the 3.8 V6, which shares the sbf bell housing configuration was last used in 2004...so looks like it will get ever harder to find a good swap candidate with low miles.
Phil
Just because you have 6 speeds doesn't mean that the final overdrive ratio will necessarily be any lower than a 4 speed...the advantage is closer ratio gears, which will get better acceleration...definitely cool, but not at that price
1 - 11 of 11 Posts
