Progress, thus far..
TCP coilovers, rack and pinion, upper and lower control arms and strut rods purchased. TCP stage II subframe connectors installed. Torque boxes installed. Tranny hump modified to fit T-56 and a custom Xmember has been fabricated incoprorating the E-brake braket. T-56, 9" 3.5:1 rear, 4.5 leaf mid eye springs, Granada disk spindles, shelby traction bars and del-alumn bushings all sitting in the shop. I'm currently replacing drivers floor, next will be tail light panel then both inner front aprons. After that, the drive line gets fitted and a alumn driveshaft will be fabricated. On to the engine.. mexican block, .030 is awaiting 331 stroker kit. plans include AFR 185 heads, stage 2, MAC intakeand 70mm TB. 77mm MAF and 36# injectors are in the garage. All this leads up to what I cant wait to start.. a custom fabbed, twin turbo setup based on Garett GTBB35 turbos that will run at 10 PSI. Add an intercoller and I'm gonna go look for Vipers and Vetts. I have pics but no web site to post so if you are interested, leave private request
