·I posted on the "old" forum regarding a 64.5 I have an opportunity to purchase for 500.00. The front frame rail on the p/s is rotted from the sway bar bracket to about 1" past the shock tower and the d/s has about a 2" rust spot.
I got an estimate from a restorer and he said it would be about 2,000-2,500 to fix. Does this sound right?
I would like to try and keep it rather than part it 'cause aside from that it's COMPLETE and would make a good un-restored driver.
I just wanted to know if the estimate sounds right(assuming I take it apart as much as possible). It's just the inside of the rails that are bad, the top/bottom/outside is solid. THANKS,Bob
