Isn't it so that the spindle is the same for disc and drum applications in V8 cars in 65-66.
What is the pricing for a decent set?
I have heard that there are plans for thicker spindles with 65-66 steering geometry but I need them now. And no, 70-> spindle is not a working solution.
Yes, the spindles are the same. Don't know about pricing though.
No it is not correct, the 65/6 drum spindles are different the disc spindles. The drum spindles do not have the attaching points for the brake calipers,
Phil
This is incorrect, the spindle is the same for the V8 models. The 6 cylinder drum spindles are different.
I've seen these go for as low as $40.
here is a set on ebay that includes the disc brake caliper mounting piece, that might be worth looking at if you need the mounting piece.
http://cgi.ebay.com/ebaymotors/65-66-67-...598153850QQrdZ1
John Harvey
65/66 6 cyl: Unique spindles, will not work with V8
65/66 V8: Minor differences in 65 and 66, can be interchanged without any problems, disk brake and non disk brake are the same.
67 V8: Disk brake and non disk brake interchange, but does not interchange with 65/66 and will not interchange with 68 disk brake. Similar set up to 65/66, shares interchangeable calipers (with correct cross over tubes) and rotors.
68 V8: Disk brake spindles are unique, have a special cast in boss for the disk brake parts. All parts basicially are different that 65 - 67. (Single piston application).
I think I have 67-> spindle because the tie rod hole is larger than 65-66. The caliper is four piston type. But I haven't measured the steering arm so that I could verify that it is not 65-66 that is reamed out or something. I wonder if there is any number to identify the year.
Secondly, sorry, I didn't quite get it, did 65-66 have a separate mounting plate between spindle and caliber and 67 an integral mounting surface?
