'65 Alternator Wiring
400 21
I have a yellow wire connected to the STA terminal on the back of the alternator.
Looks like the villainous PO set it up. I added the other wire that runs to the choke [on the SUM MV2008].
Going to a MC solid state voltage regulator causes the ALT light to flicker.
Any troublshooting help would be appreciated.
Hood Automotive tire Motor vehicle Automotive fuel system Vehicle brake
Automotive tire Motor vehicle Automotive fuel system Rim Vehicle brake
Automotive tire Motor vehicle Automotive exterior Gas Automotive wheel system
Rectangle Font Line Slope Parallel
1 - 20 of 22 Posts
@Woodchuck Sweep with lamp.
Then the following should apply... Do you have an electric choke hooked to the STA post, too? Wire to the STA should be WHITE with a BLACK tracer. Wire to FLD should be WHITE. Wires to BAT should be a YELLOW and a BLACK with YELLOW tracer. Wire to ground should be BLACK with RED tracer.
White Product Font Rectangle Material property
Black + yellow tracer = BAT
White = FLD
Yellow = black tracer = STA [will move to BAT]
Balck + red tracer = GRD
Black = STA for choke.
Sound right?
Thank you @Woodchuck 12 yo scotch next time you are in AZ?
All except for the missing WHITE with BLACK tracer that should be coming from the regulator "S" terminal to the alternator "STA" post.....
Grab a voltmeter. Set to AC volts. Attach to battery. Should read zero. Start engine and observe reading.
Edit: Also check continuity of voltage regulator chassis to ground, terminal ends in the VR plug and their snugness.
If everything seems okay, I'd try another regulator.
I notice you are missing the static suppression condenser. They are available in nice repro. That's a 65-only item. The new harness should have a plug for it.
Remanufactured alternators have the "internal" version.
Not the point. 66-up all had the internal cap. But not 65. His new wire will have the plug. Any radio-equipped 65 would have the cap. If he has a replacement alternator, sure, it'll be sure to have the internal cap, but it would cause no harm to have the external cap, too.
1 - 20 of 22 Posts
