That is a long way from BC--Where I grew up !Thanks Guys
Great call on NAPA I never even thought to check there !
C6ZZGT I'm located in Burlington, Ontario , Just outside Toronto.
That one won't work because there needs to be 2 places to connect on the bottom of the bulb versus the one. I learned the hard way and blew many fuses before I figured it out.when I search my local parts stores online they come up empty for "1142 bulb"
do you think these would work ?
1156 Sylvania ZEVO® LED Mini Bulbs | Canadian Tire
Sylvania 1156 ZEVO® LED Mini Bulbs are super bright with a high lumen output to fill the reflector with bright, intense light | Canadian Tirewww.canadiantire.ca
Amazon.ca has themSo I guess the correct bulb is 1142 which seems to be hard to find up here in Canada
Can I use another bulb like the 1156 or will that create problems ?
+Aha, just down the road from me. I'm in the Niagara area, Welland to be more precise!Thanks Guys
