Is anyone Running this setup??..Got a Pic?
. . . '65 289 Coupe, ALL Stock suspension! What is required for the 16s TTOs, haven't seen Anybody talk about them. 225 Front, 235 Rear. What parts and body work am I looking into Ordering to complete this?
I'm not quite sure why you'd want to run a 10mm tire stagger between front and rear, you lose the ability to rotate with no gain in performance and you limit your choice in tires.
I'd think a 225/50-16 at both ends would be a better choice.
TT2 16X8, 4.5 inch backspacing with 225 VR 50 tires all the way around. No clearance problems or rubs
TTO's are Torque Thrust Original. They are slightly lighter shade of gray than the D's and the center cap may be a little smaller? As far as the stagger, goes that is a preference things, I have 245 60s in the back and 215 65 in the front, I like the look. That is on a 67 though.
But to address the OP, lots of people run the TT style rims. YOu just have to make sure you get the right backspacing and tires.
Jafo
