Nothing wrong with a rack system. The problem is on a drag link system, there’s a lot going on that 99% people don’t realize. Every component on a drag link system including the spindles are designed to all work together. The exact same is true with a rack system right down to the exact location of the rack related to the axle center line and spindles. The problem with a lot of rack to drag link system is using a rack designed for something, mounting where space is available and not the correct space along with connecting the steering together. This is where issues come from. For starters a rack conversion absolutely has to emulate the drag link with inner tie rods due to the unseen and overlooked geometry. The two kits that use inner tie rods are the TCP and Unisteer.
My 66 is manual 16:1 with 4* caster and later spindles that have shorter tie rod arm which should quicken the steering a little bit. Except for parallel parking, the feel is absolutely wonderful. It telegraphs everything back to what the tires are doing. You feel the from coming up on the caster as you turn. The two things I did to my steering were fresh grease in the box and a roller bearing idler arm. That roller bearing idler arm is worth it’s $200 and then some. It really improves the response and feel. It’s far more direct and responsive. Dare I say rack like? RTC could be better but worth the sacrifice. If I went to assisted steering, not sure what I would do but I’m enjoying the manual steering too much.
