1 - 13 of 13 Posts
Does anyone have a pic of the correct retainer/bushing for the end of the trunk torsion bar on a fastback? This would be the passenger side end.
blkstlln
I've seen 2 different designs on the retainers. One was a sheet-metal push on nut, the other was a flat washer and a cotter key through the end of the torsion bar.
The bushing was a tiny little nylon/plastic piece that wasn't very durable. I replaced mine with a little bronze bushing from the hardware store. Not correct, but one helluva lot more functional.
Discussion Starter · #7 ·
Thanks Glenn,
I have noticed some used the push on, and others(like mine) have a hole drilled in the rod. Wonder if it has to do with when it was built, or a frustrated PO? :: Mine was built Sept 64. The bronze bushing sounds like a good idea.
blkstlln
The little piece on the end is called an "axle nut". Hardware stores often carry them. I used two Palnuts ahead of the axle nut to make sure the rod never comes loose. A Palnut is a washer-like device with teeth on the inner edge. Pushing it over the torsion bar results in a locked on fastener. Axle nuts and Palnuts are hardware store items.
Why is it important to properly retain this spring/torsion bar? If it comes loose at the wrong time it can slap the car body and put a nasty scar in your paint job...I know...been there done that!
Discussion Starter · #9 ·
Now there is another variation. Those axle nuts sure as heck don't go anywhere when they are pushed on. I have already heard of a story of the bar coming loose and whacking the fresh paint... :: I won't mention names ;)
Thanks,
blkstlln
The 66 assembly manual shows a push-on type fastener called a "spring nut" and lists it as # 380264-S2. It also states that "the torsion bar must be installed after the luggage compartment door" (their terms). There are other detailed instructions which I could send you in a PM if you want. In my case, I had the original push on nut, but I had previously removed it during the restoration. It's also likely that it had been removed several other times in the life of the car. Anyway, it pushed on OK and seemed to be holding. However, at a local cruise, there was this big BANG when I shut the trunk lid. It wouldn't open anymore either. At home, we were able to wiggle the trunk open enough to see what happened....the push nut had come off and the end of the torsion rod was wedged somewhere in the hinge mechanism, preventing the trunk from opening. Once things were recovered, I drilled the rod and installed a washer and cotter pin.
1 - 13 of 13 Posts
